- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
In the attached model, when I change the mantle depth parameter, it not only changes the mantle depth to the correct dimension, but offsets/changes the glass door position as well. See model and attached picture. Mantle depth should change but the glass door position should remain in place. Any insights into what I may be doing wrong is much appreciated.
PS: The brickwork design is new to me and hence not optimal in terms of workflow/methodology used but I am trying to get a quick design up and running. Any pointers on design improvement in this area will be greatly appreciated. The idea is that I wanted the brickwork to be dynamic so that it can be adjusted and used in different designs (walls, rooflines etc.
