Changing named parameters bug
When I double click a parameter to change it's value and I begin to type a named parameter (in this case "base_plate_flange_diameter"), when i get the the underscore it seems to exit out of the edit parameter dialog and then triggers some kind of shortcut (I think the shortcut for "P" which is the next letter).
This doesn't happen every time but its pretty common and is driving me nuts!
Here is gif of it:
Here is a higher quality .mov file of it:
https://cl.ly/j6W0/Screen%20Recording%202017-02-09%20at%2011.37%20AM.mov
Phil.E
This is a known issue we hope to fix in an update soon.
Can you pick the one you want off of the menu dropdown list? Those are selectable.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot
Glad it's a know issue
I can select from the dropdown but have to change the query so I only get a
small subset, which sometimes takes time to do
PS I'm unable to enter in equations in the parameter field when this issue
arrives
![](https://link.nylas.com/open/dn2ma7b65qck477cl7x4a5yl0/local-84ba3646-2b02?
r=YXV0b2Rlc2sucHJvZHwzMGY3MGRkYXwyZjE4MjI5Yy00NDU4LTRlOTAtOWI0OS00OGM3NzAwMzc3
YmJAcmVwbHkwMS5saXRoaXVtLmNvbQ==)
Phil.E
There is an update coming out tonight. Can you try this workflow again after you have updated and restarted Fusion? Please let us know if it improves.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
