changing default position in View Cube 'H`ome'
lvaszar
lvaszar
How can I change the default position of my design in the View Cube 'Home' position from Screenshot 2016-10-13 09.22.57.png
to the new default position that is rotated 180 degrees (so that the back shows):
James.Youmatz
Autodesk Support
Autodesk Support
Hi @lvaszar,
I can help you out here! Once you have the model in the orientation you want, you can then right-click the Home icon above the View Cube and then select Set Current View as Home. You have the option to choose from that view being at the fixed distance, or having it zoom to fit.
Is that what you were looking for?
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
lvaszar
That's it! Thank you kindly!
creocatia3d
Perfect!
But....Every time I open the inventor I have to configure the view cube as front, left and top and defibnir as default.
How to configure the way and always when opening this one and not the pattern of the inventor?
