Changing components origin to match assembly origin
arnou-verfaillie
arnou-verfaillie
Hello there
Is it possible to change the origin of a component to match it to the assembly origin without moving the component?
I need to import components of a robot tool into RobotStudio in order to make a mechanism for my simulation. When I import the assembly as a whole, I can't choose the seperate components. When I import each component on its own, their location is off due to the origin location. Moving and modelling in RobotStudio is rather klunky so if this would be possible in Fusion that would make things a lot easier.
Thanks in advance!
Schermafbeelding 2019-04-24 om 11.22.15.pngSchermafbeelding 2019-04-24 om 11.22.40.png
etfrench
The Move command in Fusion 360 doesn't change the component origin when you move a body. With this in mind, create a copy of the component using Copy/Paste New.  This is just to hold the position for component.  Now, move the original component so its origin matches the main origin.  Next, move the component body to it's original position using the Point to Point command between it and the copy.  Remove the copy.
ETFrench
tarheel_cnc
Solution worked!  Thanks!
