- Mute
- Permalink
- Report
I was given a STEP file for a 3/8" thick flat part. The contour has some interior filleted corners. Because it's a STEP file, there's no design history (will F360 ever support import from SolidWorks?).
One of the fillets was a 0.254" radius, but it really needed to be 0.100". I couldn't immediately figure out how to make this change. I wanted to sketch an appropriate arc and extend the two tangent lines connecting it somehow, and the press/pull that arc to cut the sharper corner, but it wasn't clear to me how.
Does anyone have an idea how to edit a fillet in this case?
Thanks!
MacBook Pro, PCNC1100 Series 3, Slant-PRO 15L Lathe, Custom AvidCNC-based 4x9' CNC Router w/24k 4.5 kW HSD Spindle & Teknic SDSK Servos
