Change scale of imported SVG
SGoldthwaite
SGoldthwaite
Currently, when I import an SVG file, the scale is always wrong.  What I do now is import it, then measure a known dimension and calculate the scale.  Then I delete the imported SVG sketch and re-import it with the correct scale.  I'd much rather just change the scale of the svg sketch I already imported.  Is there a way to do that?
innovatenate
Autodesk Support
Autodesk Support
Check out the below screencast and let us know if it helps.
Nathan Chandler
Principal Specialist
SGoldthwaite
That's what I need; thanks.
