I'm trying to simply joint a part to my design's origin on the YZ plane rather than the XY plane, it doesn't let me select any other plane than XY.
I came across this post https://forums.autodesk.com/t5/fusion-360-design-validate/joint-to-origin-only-allows-joints-paralle... where Jeff Strater mentions the reorient option, but this does not come up in my dialog box.
Solved by laughingcreek. Go to Solution.
yeah that looks like exactly what i need but i don't have that, is it a preview feature?
oh I see I have to create the joint origin first! I've never used that feature, this will save me some grief in the future thank you
Sometimes it might be useful to look a little more closely at the explanatory visuals!?
günther
