Change flow direction of pipe command
nkloski
nkloski
As the title says, is there a way to change the direction from which a pipe from the Pipe command is created?
Nick Kloski
jeff_strater
Pipe chooses its direction based on curve direction.  So, if you draw the line from A -> B, the Pipe will also go that direction.  If you draw it from B -> A, it will go that direction.
Alternatively, you can use Sweep - it gives you a bit more control
screencast:
Jeff Strater
Engineering Director
nkloski
Ok, thanks.....a bit more work to set up the sweep, but yep, that is the way, thanks!
Nick Kloski
mupshot
Community Visitor
Community Visitor
Thats fine when you are placing a pipe on a sketch, and very helpful in that regard, thank you for that.  However, the pipe is available for solid bodies as well.  is there no way to flip a pipe origin and direction when you need a simple cut on an existing body?
on a cylinder with cut out windows, I wound up using a pipe on one side, extending the distance a little for the quick fix I wanted.  However on the other side of the window to do the same operation, I had to perform the pipe, then follow with an extrude from the origin end.  seems that you should be able to reverse this operation.
