Hi SGoldthwaite,
Thanks for the screen capture. Currently we don't support custom view orientations but our designers are aware of it and it is on our list of future enhancements.
In the meantime I was able to get fairly close to your desired orientation by placing a base view with "Back" orientation then projecting it up/left (you could delete the base view afterwards) but this is not an ideal workflow. An easier way to do this (still a workaround) would be to set the orientation you want in the design, then use the "Set current view as" setting from the view cube dropdown in Fusion:
Place a standalone "Front" base view in the drawing, then use the bottom item, Reset Front in the design to return to the original settings. The view in the drawing will retain the orientation it was created with.
Chris
