Change dimension in a sketch
For some reason now I cannot change the dimension of a circle. It only lets me move the dimension number
Any suggestions?
HughesTooling
How was the circle created, is it projected? If it is not constrained to anything have you changed it to a driving dimension?
Mark
Mark Hughes
Owner, Hughes Tooling
You should be able to locate the circle in the time line at the bottom and then right click. Hopefully you see an option for edit sketch. That should allow you to change the dimension.
TheCADWhisperer
