- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello Fusion forum,
Have done this a thousand times but today it does not work.
The diameter of a circle needs to be changed as shown in
the attached JPG.
Some research in the forum confirms the way this change
has been made in the past:
- Edit the sketch with a double-click in the timeline (or right-click it & select Edit Sketch from the pop-up menu)
- Double-click the dimension and enter a new value.
- Exit sketch
But today when the circle is clicked on nothing happens.
Why does it now work?
Thanks.
Allen
PS If the center of the circle is double clicked
the Move/Copy menu appears but that is the
only reaction that can be gottrn.
