We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Chamfer with individual shape?
thburn
thburn
I have a cube and a cylinder (in sculpt mode).
Now I want to connect the cylinder (the circle of top face) to the center of one of the faces of the cube. The cylinder has a diameter of 50mm and the face of the cube is squared 70mm x 70mm.
Two questions:
1. What is best practice to connect the cylinder to the face of the cube and get one single body?
2. I want to have a nice transition between the cubes face and the cylinder. Therefore I can use bevel (in sculpt mode).
Bit I don't want to have a bevelled edge between cube and cylinder but a nice rounded transition.
Best would be if I can define a spline and use this spline as shape for the transition similar to the revolve tool.
Can it be done? How?
Thanks a lot!
rishivadher
Hi thburn
You have to “bridge”, and select the surface of the square and the edges our the cylinder
Our if the cube is and cylinder are solid, and not b-rep, the “loft” between the the surfaces
Best Rishi
thburn
Hi rishivadher,
thanks for reply, OK but is there a way to influence the roundness of the transition?
I want to get a certain shape based on a spline to get the transition between cylinder and cube smoothed out.
How can I do that?
Oceanconcepts
It depends somewhat on what you are after. If you are in sculpt using T-Splines (Bridge example) you can add edges to the transition area and use the sculpting tools- Edit Form. That will allow you to be reasonably accurate, but not precise.
- Ron
Mostly Mac- currently M1 MacBook Pro
rishivadher
Hi thburn, sorry for the delay on the answer
The answer of Ron is what I had in mind but just now made an example, of adding more faces to the cube and cylinder
You can also exam the curvature in “inspect” to see which works better in each your case.
Best Rishi
thburn
thanks for all who helepd me out!
