Chamfer Mill
Chamfer Mill
dandonegan
Chamfer Mill
dandonegan
I am attempting to add chamfers to my parts. Supposedly when I go to 2-D profile in selected chamfer tool a chamfer dialog box is supposed to appear in the passes tab. I've searched for it everywhere and cannot find it. Did something happen to it during the upgrade or am I looking in the wrong spot?
Dan
jeff.walters
This is a known issue and has been talk about in our autodesk CAM forum. Hansun one of our Fusion support people posted the below, and one of our users Lonnie.Cady also posted a video showing the workaround.
Hi all, We are sorry for the the chamfer option issue in 2D Contour and Trace of the chamfer tool. This is a known regression which was found and fixed, but we was not able to make it available for release in the last minute. Sorry for any inconvenience. And there is a workaround, you should be able to see and modify the chamfer values in the Compare and Edit dialog although it cannot be toggled on and off. Sorry again and please let's know if you have any questions. Thanks Hansun
https://screencast.autodesk.com/main/details/5fdc1951-3c39-4939-8abd-aa5e59582089
Jeff Walters
Senior Support Engineer, CAM
