CHAMFER angles arent consistent
programming2C78B
Mentor Mentor
programming2C78B
these 2 corners are both supposed to appear mirrored to each other
Please click "Accept Solution" if what I wrote solved your issue!
SaeedHamza
We can't help unless model is shared, please go to file>export>.f3d and attach so we can take a closer look
Saeed Hamza
etfrench
If all of the edges are selected at once, they share the settings.  If edges are added afterwards, the desired settings must be set.  In other words, each line in the dialog has separate settings.
ETFrench
programming2C78B
you dont need a model, it happens on anything.
johnsonshiue
Hi! I believe this is a UI confusion issue. The Distance/Angle Chamfer should only allow connected edges to be selected. When non-connected edges are selected, the face reference would need to be supplied. However, there isn't a workflow to do that.
In this case, to avoid the confusing result, the Chamfers will need to be created separately (one chamfer per edge).
Many thanks!
Let us know how we did on Trustpilot.
Software Test Engineer
etfrench
Definitely a bug:
ETFrench
