Announcements
Chamfer and Fillet
mohammed
Chamfer and Fillet
mohammed
Hi there
I'm really stuck on trying to model up a bluetooth speaker.
The long edges are actually flat, so doing a fillet on all the edges of a cube wont work. I need to somehow do a chamfer on the edges, merging in to a fillet in to the corners.
Any idea how I could go about doing this? Or is this something I need to do via Sculpt?
(It is a Sony SRS-X11 if anyone needs to search for more detailed pictures)
Thanks!
Replies (12)
etfrench
This was done with a hollow quarter sphere to round the corner (using Combine|Cut) plus chamfers:
And with the chamfers filleted:
Sculpt would be  your best bet.
ETFrench
TheCADWhisperer
See Attached file.
If you are a student - you can get free access to Autodesk Inventor Professional with more control on Setback.
mohammed
Thanks so much for the help.
@TheCADWhisperer that is a great, I haven't used the surface tools to do something like this before!
jeff_strater
@mohammed , this is an interesting geometry problem.  Actually, @TheCADWhisperer , I don't think that Inventor can do this either.  I think that there is no control over setbacks for a Chamfer in Inventor (other than off/on).  However, my Inventor knowledge is out of date, so maybe that was added recently.
In addition to @etfrench 's approach, I was able to do this, very painfully, by:
  1. creating a Fillet with setbacks
  2. in Surface/Patch, delete all the Fillet faces
  3. create a 3D sketch to add geometry between the corners of the former setbacks
  4. surface loft the "chamfer sections".  Sweep would work here, maybe even Extrude.
  5. Use Boundary Patch to create the corner patches
  6. stitch the whole thing back together
As I said, painful, but gets the job done:
Jeff Strater
Engineering Director
TheCADWhisperer
I taught surface modeling before I taught parametric solids modeling.
Over the years I have collected a fairly large number of examples of what looks like simple geometry that turns out to be much easier to create using hybrid solid/surface techniques.  I use this collection of examples when (re)training experienced users who think that surface modeling is only for organic geometry.
I have a couple of examples that I let them "chew" on for a couple of hours and then demonstrate hybrid solutions that take less than 5 minutes.  It always catches their attention.
It was late last night when I through together this example.  I was a bit disappointed that I could not find a way to control Setback the way that I can in Inventor.  One thing I didn't check is how much difference setting to G2 on edges 2,4, and 6 would return.
TheCADWhisperer
If you examine  the *.f3d file that I attached - I did not use any Chamfer features.
Modeled the same way in Inventor that I modeled in Fusion 360, except that I had control on Setback. (see Attached)
In this example .125 x .5 Setback.
I exaggerated the setback in the above image compared to the original part image to clearly illustrate.
mohammed
What you've done in Inventor here is the exact representation of the part - shame Fusion doesn't have this setback support!
TheCADWhisperer
@mohammed
Another technique (see Attached).
mohammed
Fantastic @TheCADWhisperer , that is a great way to do it! Thank you
ALan.cardenasXKPGW
Observer
Observer
Thank you sir.
gabor.kugler
Somewhat late to the party, but here is another solution:
1 - Create chamfers on edges:
2 - Extrude surfaces on sides.
3 - Fillet corners on surfaces.
4 - Create datum planes at fillet start/end position.
5 - Split side faces with fillets and chamfered faces with planes.
6 - Create surface patch from these edges.
7 - Replace split faces with patch.
This method is very stable and works with both tangent and continuos fillets. Also with different chamfer and fillet sizes.
(in this case you need to be clever when creating the datum planes)
JamieGilchrist
Hi @gabor.kugler you can also use the fillet command, select all the faces, and set your corner type to Setback and drop the tangency weight way downScreenshot 2024-05-21 at 1.44.37 PM.png
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
