Chain Faces Question
I am following a tutorial given by Lars Christensen. Fusion 360 For Absolute Beginners Part 2, 10:40 into the video. I have done this about 8 times and I continue to get the same result. The extrusion does not chain the faces together as Lars is discussing. The outside of the boss should meet the box entirely around the circumference, and this is accomplished by chaining the faces. But when I select "Chain faces" in the extrusion properties, it doesn't do the same as Lars' does. Before I built this super computer I was trying to work with Fusion on a sub par computer. I learned that if each phase of a model is not right, things will not work or fit later. A step like this seems to be critical in the final results. Especially if it is going to a router or printer. Can someone look at my model (attached) and see what setting is not right? Thank you all for looking and your response.
