Centre Point Rectangle Shortcut or make as default
philwmcintosh
philwmcintosh
I never realised until recently that I use centre point rectangles 99% of the time but AFAIK the only to make one is press shortcut "r" then mouse to a centre point one. I looked to see if there was a shortcut to it but no. I looked to see if I could make that the default when I press the shortcut "r" but it doesn't seem possible. There was a thread about customisable hotkeys but that didn't gain traction. I know it'd only save me one mouse movement and click but it'd increase my speed if such a thing were possible. Any ideas?
jhackney1972
You can always place it on your sketch toolbar for a quick click or you can place it on your Shortcut menu.
John Hackney, Retired
laughingcreek
@philwmcintosh wrote:
... I looked to see if I could make that the default when I press the shortcut "r" but it doesn't seem possible...
It's possible.  pull the menu out and select "change keyboard short cut"-
and then except the change in the next dialog
paulmcevoy75
is there a way to make center rectangle the default rectangle?
laughingcreek
Yes.  Follow instructions in the post you responded to.
