Centering a simple rectangle to a construction line?
jonYDM8U
Message 1 of 8
jonYDM8U
Ultra beginner moving from Sketchup to fusion.
I'm so lost and I've searched high and low for the solution but I don't know how to word it to get the answer.
1.  What are constructions lines for?
2.  How do I align sketch elements to construction lines?
Draw a rectangle 6mm wide by 1.4mm high.
Draw a horizontal line that acts as a guide, let's say 10mm long.  Position that line below the long edge of the rectangle.
Move the rectangle down so it's centered vertically on the line (the line cuts it in half exactly at the center of the short sides.)
I'm on hour 2 trying to do what I imagine is a very basic task.  No clue.
Replies (7)
Message 2 of 8
jhackney1972
Construction lines are used to help you position and locate other sketch entities.  You can use construction lines for any shape such as a circle for location of a hole pattern, or a line, as I did in the screencast to locate the rectangle you asked for.  Along with sketch constraints, you can position almost any sketch in the correct location.  Construction lines are ignored by the application during modeling operations so they do not influence your design.  The main thing to remember during sketching, make sure your sketches are fully constrained by sketch constraints and dimensions, normally in that order.
John Hackney, Retired
Message 3 of 8
HughesTooling
Did you try any of the tutorials in the help?
Maybe start here.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 4 of 8
jonYDM8U
I did...I managed to figure out one way to do it, but it feels like it's inefficient.  Still learning.  Thanks!
Message 5 of 8
jonYDM8U
Thanks.  It's going to take a while to figure out the ins and outs of the interface.
Message 6 of 8
HughesTooling
Creating parametric sketches is a skill but once you get it figured out it is very powerful and just as quick to create as dumb cad sketches.
Mark
Mark Hughes
Message 7 of 8
kwotring1
@jhackney1972I know this isn't my post, but I just wanted to say thank you for the video, it was most helpful!
Message 8 of 8
chrisplyler
If you ONLY want a line that bisects the rectangle vertically, without regard to any other constraints or relationships, sketch a Point. Constraint that Point the be Midpoint along one of the vertical sides of the Rectangle. Constrain that Point to be Coincident to the Line.
Now the Line will always bisect the Rectangle. The Rectangle and the Line are still free to move horizontally relative to each other, but their vertical relationship will be constrained.
Without any other relationships defined, it should look something like this:
