Centered rectangle with fixed radius corners?
feklee
Message 1 of 8
feklee
How do I create a rounded rectangle with the following constraints?
  • Fixed corner radius: 3 mm
  • Center of the rectangle: origin
Later I want to be able to resize the rectangle entering precise numbers. The corner radius should not change, and it should remain centered.
Replies (7)
Message 2 of 8
jeff_strater
hi @feklee,
Yes, you can do this.  It's a little tedious, unfortunately, due to a bug in Fusion where the sketch fillet will delete the coincident constraint to the construction lines, so you have to go back and re-apply those.  But, the rest is pretty straightforward:
Jeff
Jeff Strater
Engineering Director
Message 3 of 8
feklee
Just replicated what you did, and it works flawlessly. Thanks!
Still I'm not sure if I understand what the Coincident constraint does.
Message 4 of 8
HughesTooling
Here's another way that's quite quick. But the best advice is leave the corners sharp in the sketch and fillet the 3d feature after extruding.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 5 of 8
jeff_strater
I like @HughesTooling's method.  Quite slick
Regarding Coincident, it can be used for a couple of things:  Making two points stick together, or constraining a point to be on the infinite extension of a curve (line, arc, spline, etc).
Here's a quick video show how this works with a point and a line:
Jeff
Jeff Strater
Message 6 of 8
feklee
Thanks for the video about the Coincident constraints, very instructive!
Message 7 of 8
feklee
@HughesTooling Thanks, that looks like a nice solution! What took me a while to figure out is that one needs to hold shift when selecting the side of the rectangle with the Horizontal/Vertical constraint selected. I wonder where that is documented.
Message 8 of 8
HughesTooling
Shift to select midpoints was implemented a while ago. You used to be able to pick midpoints without the shift key but it got in the way all the time, you'd be trying to add an angle dimension between 2 lines but end up picking a midpoint and get a distance instead.Smiley Frustrated It was announced in a What's New but don't know where you'd find it in the help.
Mark
Mark Hughes
