Press Pull: Selecting faces only?
feklee
feklee
When using the Press Pull command I restrict selection to faces only?
By default it is hard to select small faces, as Fusion prefers highlighting edges over faces. So I need to zoom in, select a face, zoom out, then zoom in on another face, etc.
jeff_strater
use selection filters to control what is selected.  By setting the filter to "Body Faces" you can more easily select just faces
screencast:
Jeff
Jeff Strater
Engineering Director
feklee
Perfect, thanks!
