Capture position enabled
jezek.jaroslav
jezek.jaroslav
is there a way to enable Capture position when moving parts ?
I see I have to confirm every time when I move part or there is a check box in the feature dialog window.
But still I have to check this box everytime I use the move command.
Is there a way to enable capturing forever ? (with no need to confirm) 🙂
JJ
pavmed
No, there's no option to get it ticked by default.
For me it seems something could be wrong with workflow if you need a lot of component moves with capture position after each.
Could you share what you're trying to accomplish?
I see several possible solutions depending on what you're doing.
