capture patterns to scale
I have several 2d patterns that are made of plastic sheeting.  The size of these sheets can be as much as 7' x 10' and made of plastic, they can have complex curves.    Is there anyway to capture these patterns and import them into CAD. So I can save them.
SaeedHamza
Could you please provide a picture
Regards, Saeed
Saeed Hamza
example of the pattern
g-andresen
if I have properly understood the question, this could be a way.
The photo should be created from the vertical.
günther
SaeedHamza
The best thing to do is to sketch them inside Fusion, and if the are too complex to do so you can use Illustrator to convert them into AutoCAD lines and then insert them into Fusion as profiles
Regards, Saeed
Saeed Hamza
