- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi All,
My latest Modelling attempt is an Airliner, based upon a Tutorial Set I have located.
How To Start Designing RC Airplanes in Fusion 360 Tutorial [Episode 1] - YouTube
As in the Tutorial, I located a Three View of the Airliner and imported it into Fusion. The only processing I did was to
cut the largest .jpg of the image into three separate views but otherwise left them the same relative size. The original
image, from memory, was about 1200 x 800 pixels.
When I imported the .jpg into Fusion I did not know what Scale to use. My initial thought was that the original
image was not small, so I only Scaled it to 5 times. After importing and lining everything up, I started my first
Sketch to find that the Canvas was Tiny. Below are the Front Views that after being Scaled to 5 the Fuselage is only
9.5 MILIMETERS! Way too small. (The round cabin bit without the wings for those who don't speak Aeroplane 😎).
I made the Scale only 5 as when I enlarged the images they began to Pixelate and fade, as .jpgs do. The Tutorial,
after I had imported mine, used a Scale of 20. This would give a Fuselage Diameter of 36mm. This is still too small
for the final Model I want. A quick calculation of the Diameter of the Fuselage would make 6.22m about 260mm for
a 1/24 Scale Model. In theory this Model could be set up as an actual Radio Controlled model. The Tutorial involves
setting up Laser Cutting and such from the Model, which is what peaked my interest to extend my skills.
After all of this explanation, I suppose I should ask a Question.
Why was my Canvas so Small? If I want a Canvas of a Specific Scale, how do I calculate the Scale Factor before I
start drawing? If I have to make a BIG scale, what can be done about Pixelation?
In theory I could convert the original .jpg to a .svg file for scaling. I had to convert my .png to .jpg to start and I
am concerned that something will be lost with all this converting. Is it just me or does Fusion not like importing
other than .jpg as a Canvas?
I have also found that .svg files slow my machine down heaps when I re-scale just the view sometimes.
Final question. I imported the Front View of the Cockpit (Pointy End), but in the Tutorial they used the Cutaway
View. I didn't try it but, does Fusion get upset if I put two Canvas images on the same Plane in the same place
or do I need to create another Plane, or can I put them both there separately and just turn them on and off like
normal?
Thanks in advance for help.
Cheers
Andrew
