canvas image not clear
Hi I've used this to to be used as a canvas image.
but after adding the canvas image I get this making it extremely difficult to calibrate the image.
but if I do calibrate using the image like this.
the problem seems to disappear.
Phil.E
Thanks for posting this. I would like to investigate.
Can you please attach the image, and let me know what OS you use?
If anyone else has seen this please chime in.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Hi Phil.E
Here is the attached file you requested and I'm using windows 10
Phil.E
Thanks. I can't reproduce the issue. Let me know if you find it happening often and with other images. Very likely this is a graphics issue, so check your drivers if you see this again, or other graphics issues.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Thanks for looking Phil,
I thought it might be a problem with the importing of the file because if I leave it at the size it comes in at, select calibrate and don't change the size just accept the current size the image updates and is ok.
