Assembly joint to tapered angle
How do you joint to angle.  In this example, I have an 82° cap screw that I want to joint to the counter sink in a cap.
davebYYPCU
Select top face of screw, and
the centrepoint of the hole in the plate.
Might help...
jhackney1972
@davebYYPCU has given you the answer, I am attaching a Screencast to back it up.  I forgot to mention you can tweak the depth by dragging  the axis, probably Z axis, of typing in the matching axis in the dialog box.
John Hackney, Retired
