Cant figure out loft
Im a new user to Fusion 360 and I have these two identical sketches I want to loft together in order to make a twist, but I just can't seem to get it to work properly.
One image is of my sketches and the other is a similar result to what I want.
Any help would be greatly appreciated. Thanks!
jeff_strater
I think I understand what you want.  The trick is to double-click on the loft mapping points, then you can drag them all at once.  This allows you to twist the loft.  See the screencast.
However, in your design, there seems to be a bug.  But, if you trim out the interior arcs, it does work.
Hopefully this give you some idea of the way to go.
Jeff Strater
Engineering Director
