Cant delete lines
Cant delete lines
Cant delete lines
Hi, tried to modify an existing model and have some problems with a geometry there. I've reduced the thickness of a body and lines are kept, neither able to delete or form (want to delete them). Any ideas, suggestions? Thanks a lot
TheCADWhisperer
File>Export and then Attach your *.f3d file here.
laughingcreek
one of the many many pit falls associated with converting a triangulated mesh (stl) to a brep.  When ever possible it's better to rebuild the model using native fusion geometry.  All the little faces created from the mesh conversion are difficult for fusion to deal with.
