Sorry in advance if the answer to this is obvious or if I missed the answer somewhere in the forums.
I'm using Fusion to design parts that I'm 3D printing and it's pretty common for me to revise a design after trying the printed part. After I cut one object out of another, is it possible to change the dimensions of the object that was cut out? For example, suppose I created a box and then created a hole through it by creating a cylinder on one of the box's faces using the "cut" operation. When I do that, it appears that the box's mesh is modified and there's not a separate cylinder object for me to resize.
If this isn't possible, is there another way to cut objects from others that would allow me to modify them after the fact?
Brandon
