CANT CONVERT MESH TO T-SPLINE
asif.ahmed.cr7
Message 1 of 14
asif.ahmed.cr7
I have tried reducing the mesh many times but still, I failed to convert it to T-Splines, I have tried to convert to quad mesh but failed to do that also in Fusion 360 and Meshmixer.
Replies (13)
Message 2 of 14
TheCADWhisperer
Can you Attach the original file here (preferably in state before attempting to reduce face count).
Message 3 of 14
asif.ahmed.cr7
Here is the quad mesh file
https://drive.google.com/file/d/1XQ990Zu2CwDM7TNuMheyx8TS4CZdSkZI/view
Triangle mesh file
https://drive.google.com/file/d/1d4OF7nsOKM2ewD0jQ48LzgoiZBwbF-6h/view?usp=sharing
I want to convert it into T-Spline and save it as STEP file
Message 4 of 14
asif.ahmed.cr7
can you help me to do the conversion?
Message 5 of 14
TrippyLighting
Why would you need such a dense mesh to convey such a simple shape?
A clear indication that this will not converter is the sheer size of the quad mesh file. A .obj file with 170+ MB size contains a LOT of mesh data. In this case It's over 1 million faces. It helps to pay a little attention to some basic details.
You can likely get this shape represented by a mesh with 100 times or fewer polygons.
If I had to model this from scratch, the control cage would have less than 100 polygons!
I remeshed one of the meshes with InstantMeshes to a mesh with 10k polygons. This is the result:
Message 6 of 14
BrandonMac
Fusion just upgraded and i can't see the CONVERT MESH TO T-SPLINE option whats going on?
Message 7 of 14
TrippyLighting
You can find hat option in  "Modify->Convert"
Message 8 of 14
BrandonMac
Ahh I see it now was not showing up in the right mouse button but see it in the menue.
I have a question when converting a mesh to Step I use mesh to t-spline then to Brep when i export object to step it makes a error saying i need to include the t-splines as well.  any idea what i doing wrong?
Message 9 of 14
TrippyLighting
I don't think that is what the error says. Can you post a screenshot, or even better create a screencast of your workflow ?
Message 10 of 14
BrandonMac
Message 11 of 14
TrippyLighting
That is just a warning. As you already have converted your T-Spline the export should just work.
Message 12 of 14
BrandonMac
Ahh I have exported with this error however its very off putting and buggy. Looking for the model 70% of the time it's missing. Can you report this or check?
Message 13 of 14
BrandonMac
This shows that is is working even with the error that need to go away in my humble option I spent a few hrs trying to understand this warning. lol
Message 14 of 14
BrandonMac
Now it's working thank you so much letting me know about the warning message
