Cannot use Emboss
Cannot use Emboss
eric.thepaut3
Cannot use Emboss
eric.thepaut3
i would like to use emboss, but the surface on which i want to emboss my sketch is the only one i can't select. I don't understand.  I want to project the bat on the guitare top curved face....
Here is my build : https://a360.co/3sSqfh3
jeff_strater
Emboss today only works on relatively simple surfaces (cylinder, etc).  However, we are working on a more complex version of emboss that will handle doubly-curved surfaces.
Jeff Strater
Engineering Director
eric.thepaut3
Ok, thank you for your quick answer. But so bad actually...
What could i use to mimic emboss? Project?
jhackney1972
You said you wanted to Emboss, which is raised.  Your model as downloaded was Deboss, which is cut into the surface.  I did an Emboss, it can be reversed and you can close in the center or made multiple heights.  You tell me.
John Hackney, Retired
eric.thepaut3
When i load your file, i have this message... Do you know what it means?
g-andresen
The file is created with a newer version of Fusion.
If your system is updated to this version it should work.
günther
eric.thepaut3
Thank you guy. I finally did it!!!
