Cannot set prescribed translation constraint
Hello! I need help. I am trying event simulation for the first time. I am trying to use the prescribed translation constraint, as instructed by our professor. However, when I do so, the OK button cannot be clicked after I set everything up. What shall I do? Thanks!
TheCADWhisperer
Can you post the complete instructions here?
Have you asked your professor?
dikshant.
You've likely not defined the multiplier curve. Select the "Multiplier curve" option to define how the motion takes place and its magnitudeEdit the multipliers on the right pane & changing the inclination of points on the curve sets whether the motion is uniform, accelerating or de-acceleratingEdit the multipliers on the right pane & changing the inclination of points on the curve sets whether the motion is uniform, accelerating or de-accelerating
