cannot select everything by dragging over model to stitch surfaces
cekuhnen
Mentor Mentor
cekuhnen
I have to select everything in the browser by hand.
https://drive.google.com/open?id=0Byzv_NlyKp_2RGFRbko1WFBBeFU&authuser=0
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
innovatenate
Autodesk Support
Autodesk Support
Do you have the "Select Through" option enabled in the selection filters?
Pardon the awful audio quality on this one...
Nathan Chandler
Principal Specialist
cekuhnen
Yep
Claas Kuhnen
innovatenate
Autodesk Support
Autodesk Support
Just curious about this...
If you drag the selection box from left to right, you'll see the selection box has a solid line. If you drag from right to left, you'll note the selection box has a dashed line. The solid line indicates that everything must be 100% within the selection box in order to be selected. The dashed box can only partially contain geometry in order to select it.
Does this make a difference for you?
Nathan Chandler
cekuhnen
I quite and restarted Fusion without changing any settings.
It works now as it should.
Claas Kuhnen
