Cannot select edges for Chamfer
AgileJohns1411
Message 1 of 12
AgileJohns1411
Hi Folks,
I am not able to select the edges for a chamfer to execute a 1.5 mm equal chamfer. There were a few threads regarding the same issue but it was mainly due to the complexity of the model or due to the radical chamfer value but in my case, it is a simple model.
Here is the model https://a360.co/2FLWtD1
Thanks for your help,
Agile
Replies (11)
Message 2 of 12
karina.harper
Autodesk Support
Autodesk Support
Hi @AgileJohns1411
This is due to the body being set as "unselectable".
You can turn this off by right-clicking the model and clicking "selectable/unselectable".
Message 3 of 12
AgileJohns1411
Thanks, Karina
It worked and saved me a lot of hassle 🙂
Message 4 of 12
razvaneagoe
Community Visitor
Community Visitor
Same problem here, but could not solve it yet. It's a STL file for 3D printing (PLA) that I'm trying to modify. I just want to add a chamfer to one edge, that's all.
I cannot select any face or edge, there is no edge or face highlighted as I move the cursor. Please help!
Message 5 of 12
g-andresen
chamfer needs a solid body
First convert the mesh body into a solid body.
The solid must then be "cleaned up" so that an edge is created that can be chamfered.
please share the file
günther
Message 6 of 12
razvaneagoe
Community Visitor
Community Visitor
Thank you so much, that was it! I converted it into a solid, then chamfered easily the edge I needed, then converted back to STL. Problem is, now it is HUGE and does not fit into the printer 🙂 But I feel like I'm making progress!
PS: if STL files are "unitless", how does the 3D printer know the size of the part?
Message 7 of 12
AgileJohns1411
@razvaneagoe
Great, that it worked
If the size is huge, better to split it. I used to split the bodies and make threads to join the bodies
In some places even snap or slide in groove fittings will also work. I will recommend to check the load and direction of load under stress before choosing slide, groove or threaded option.
Message 8 of 12
TheCADWhisperer
@AgileJohns1411
Incorrect information.
@razvaneagoe
When inserting the file select the correct Units.
Message 9 of 12
g-andresen
open STL via INSERT > insert mesh
günther
Message 10 of 12
AgileJohns1411
@TheCADWhisperer
Thanks for pointing out, can you let me know what was the incorrect information?
Message 11 of 12
AgileJohns1411
@TheCADWhisperer
Thanks for pointing it out, can you share what was the incorrect information?
Message 12 of 12
g-andresen
@AgileJohns1411 wrote:
@TheCADWhisperer
This surely means that you replied via post reply to the thread opener and not directly to my post.
günther
