Message 1 of 10
10:00 PM
Not sure if this is a bug or if it is by design. I did a screencast to show the issue.
Anyway, when I create a body inside an uploaded step file I cannot offset the body using the press/pull command. It does not give you the ability to highlight all the faces. In the screencast you can see there is an option missing the moment you click a face inside the uploaded step file.
