Cannot offset a body inside an uploaded step file
Message 1 of 10
Not sure if this is a bug or if it is by design. I did a screencast to show the issue.
Anyway, when I create a body inside an uploaded step file I cannot offset the body using the press/pull command. It does not give you the ability to highlight all the faces. In the screencast you can see there is an option missing the moment you click a face inside the uploaded step file.
Replies (9)
Message 2 of 10
lichtzeichenanlage
You haven't inserted the screencast after you have selected it from your list. So we don't see it.
Could you share the model, too?
Message 3 of 10
sorry, I did not click the 'insert' button.  I edited the post.
Message 4 of 10
lichtzeichenanlage
Have you tried to enable the design history?
Message 5 of 10
etfrench
This technique may work for you if the step file is not too complex:
ETFrench
Message 6 of 10
lichtzeichenanlage
@etfrench: Do you know that the shell command can process more the one face at a time?
Message 7 of 10
etfrench
It's been three or four updates since I last used the Shell command Smiley Happy
ETFrench
Message 8 of 10
Thanks...enabling that did the trick. much thanks.
Message 9 of 10
etfrench
Press/Pull works in Direct Modeling mode as well.  It's a matter of which face(s) to select:
ETFrench
Message 10 of 10
lichtzeichenanlage
Strange - I've created an STEP-File on my own and wasn't able to select the fillet.
