Cannot lock some sketches
wadeJ4J2S
wadeJ4J2S
Sketches 2 and 4 cannot be locked, even though they are black, and I cannot figure out why.
I'm new to Fusion 360, but did all the tutorials and still cannot find the answer.
Help and explanation would be much appreciated.
g-andresen
here is a screencast of sketch 2 and 4.*
Check the other warnings, especially those in sketch 1.
günther
* If necessary, the construction lines can also be defined.
etfrench
Enter the command Sketch.ShowUnderConstrained in TEXT COMMANDS entry field to see all of the unconstrained geometry in a sketch:
ETFrench
TheCADWhisperer
Why two threads on this topic?
https://forums.autodesk.com/t5/fusion-360-design-validate/cut-type-extrusion-does-not-remove-outside...
It is best to keep discussion within a single thread.
