Angle a component in two directions (multi angle)
john.n.johnson
Message 1 of 11
john.n.johnson
The attached illustrates a component (leg) which leans back at 51 Degrees. I need to keep this angle but also have the component angled inwards to join the top of the table. I then need to mirror the leg to the opposite side so that it too, angles inwards to joint he top of the table. Any help will be greatly appreciated.
Replies (10)
Message 2 of 11
davebYYPCU
One way to do it is with 2 sketches, one has the 51 degrees, and a plane from that line for a second sketch for the other angle.
A second way is to use a 3d sketch but harder to manage.
Might help....
Message 3 of 11
etfrench
  1. Draw it flat.
  2. Use the Draft command to put the angles on each end.
  3. Use joints to connect it to the table top and bottom.
ETFrench
Message 4 of 11
g-andresen
just try it this way
günther
Message 5 of 11
john.n.johnson
Thanks much Dave. Very Helpful and works as a solution.
Message 6 of 11
john.n.johnson
Thanks for the help etfrench. Another great helpful insight. It works.
Message 7 of 11
john.n.johnson
Thanks very much Guenther. Very helpful indeed. Solution works well.
Message 8 of 11
g-andresen
Here  is another more practical solution.
günther
Message 9 of 11
john.n.johnson
Hi Gunther (sorry that I could not include the "umlaut" in your name - USA
keyboard). Many thanks for your valued support. Your latest proposed
solution is simple and well explained/illustrated. I did use the Angle Plane
Feature to get the angles I needed. Your illustration is more
"scientific/accurate" and allows for more flexibility. I included a rendered
picture of the table saw outfeed solution that I needed the solution
for...thought I would share it with you.
Many thanks
John
Message 10 of 11
john.n.johnson
Looks like the attachment did not come through in my response. So here it is again. Many thanks to all.
Message 11 of 11
g-andresen
Then I wish you that you can implement the project as planned.
günther
