Cannot fully constrain simple sketch
christian_harwood
Message 1 of 17
christian_harwood
I have an extremely simple sketch that I'm not able to fully constrain. Here's a recording of creating the sketch in a new design:
I'm not able to drag the unconstrained line, or add any additional constraints.
Replies (16)
Message 2 of 17
kacper.suchomski
Hi
Is there a lock next to the sketch icon in your browser?
If so, it's just a graphical error.
If not, please attach your file.
Kacper Suchomski
Message 3 of 17
Drewpan
I have followed your video exactly and mine is fully constrained. Why do you
believe it is NOT constrained? There are two different coloured lines on the
two Construction lines but that is an artifact that occurs because one was the
line you selected to put the Midpoint constraint to the Origin. The Lock Icon
says the sketch is fully constrained. You can make both of the construction
lines the same colour simply by selecting and unselecting one or both. The
Lock Icon is the most important thing here, not the different coloured lines.
Cheers
Andrew
Message 4 of 17
christian_harwood
The lock icon is not shown, so it doesn't appear to simply be a graphical error. I'm not able to upload the file at the moment, but it should be easy to reproduce.
Message 5 of 17
TheCADWhisperer
@christian_harwood
Worked fine for me.
Message 6 of 17
kacper.suchomski
I wouldn't ask for this if it were easy to recreate.
Kacper Suchomski
Message 7 of 17
christian_harwood
@TheCADWhisperer @kacper.suchomski @Drewpan Here's a file containing the problem.
Message 8 of 17
TheCADWhisperer
@christian_harwood
Wow, that is a strange one.
I can reproduce the issue with your file, but my file works fine.
Can you reproduce the issue in a New File?
Message 9 of 17
kacper.suchomski
The file appears to be corrupted.
It's missing one constraint (not required from a logical perspective), but it can be fully constrained by adding a perpendicular or coincident-to-origin constraint.
But that's a file error.
If you create a new file everything should work.
Kacper Suchomski
Message 10 of 17
christian_harwood
@TheCADWhisperer @kacper.suchomski I've tried in a new file after restarting Fusion and still have the same issue:
For reference: I'm running Fusion version 2604.1.25 x86_64 on Windows 11 Pro 24H2 build 26100.6584.
Message 11 of 17
davebYYPCU
Bug appears to be the order of operations.
Same as the movie, with one of the construction lines, set midpoint to Origin, all 5 articles are black,
then draw the last construction line, works as expected, here.
(I use Centre rectangles for this result.)
Might help....
Message 12 of 17
christian_harwood
I think something is seriously wrong with the constraint solver in my version. Minor changes to existing sketches such as adding a new fully constrained point cause half the sketch to become unconstrained. It also seems to be highly reliant on order of operations - when adding a dimension, it will be fully constrained if I click point A then point B, but if I reverse the order it will have errors.
Message 13 of 17
davebYYPCU
Same version here, does not happen to me.
Message 14 of 17
billbedford
No, the two construction lines were never constrained together. They were constrained to having equal lengths. To constrain their midpoints together the MidPoint (triangle) constraint should have been used.
Message 15 of 17
billbedford
Depending on the place in the point stack each of the line's centres occurs, there is a 50% chance that the coincident constrain will link both lines with the origin point.
Message 16 of 17
johnsonshiue
Hi! The issue seems to be related to the coincident constraints. If I add sketch points at the intersections, the sketch will be fully constrained. But it is puzzling to me, why coincident constraints were not added appropriately.
Many thanks!
Software Test Engineer
Message 17 of 17
davebYYPCU
In the movie, the last construction line has not been associated to the Origin.  It should be black, because it can’t be moved..
Centre point rectangles come with the coincident point at the intersection of the construction lines.
Its order of operations bug, this actual construction, order - highlights why no one has found it before. (Equals on the construction, and not the boundary) (Most would set boundary midpoints, horizontal vertical, without those construction lines)
Might help….
