Cannot extend extrusion to object
markKM8CP
markKM8CP
The sketch will cut the object when drawn on the YZ plane, but not on the XZ plane.
Not sure why ...
Thanks!
TrippyLighting
If you change the Extend Type from "all" to "Distance" with an appropriate value it'll work.
markKM8CP
Thank you, works fine ...
jhackney1972
It is normal practice to mark the post that gave you the solution to your post with an "Accept Solution" and not your post thanking them for it.  Please correct this!
John Hackney, Retired
