Cannot Edit Sweep Profile
I'm trying to edit a sweep that I have done as part of a wing. I have found that any attempt to reselect the profiles to be swept fails to generate the sweep properly. This is a problem because I want to also edit the interior of my wing as I only have a placeholder interior as of now. If anyone can figure out what's causing the failure, that'd be great!
I've added a screen recording of what happens below.
Thanks, Shihao
laughingcreek
can you attach the file? (export f3d from file menu and attach at bottom of post)
Yep, here you go.
laughingcreek
Fusion seems to be getting confused by that one line segment that doesn't seem to be serving a particular purpose.  Changing it to a construction line cleared things up.  See screen cast. (I also took that extra line segment off the path b/c it was bugging me)
@jeff.strater-this feels like a bug related to how fusion keeps track of profiles, what do you think?
Thanks!
I completely missed that extra line that I had on the profile. Now with that removed, everything works.
jeff_strater
very strange, yes, this is a profile tracking bug, I'd say.  Filed as FUS-39238
Jeff Strater
Engineering Director
