Im making a hollow cone. Its an adapter for a shopvac hose to a table mire saw.
I made 2 small circles (42mm, 45mm D) on a plane. Then made 2 bigger circles on the same plane (58.5mm,61mm).
Then use move-sketch object and move the bigger circle 40mm along a perpendicular path.
Then use loft to create the cone between the 2.
All this worked fine.
Now i need to increase the size of the larger circle, but the dimension tool wont let me select it. I can dimension the small circle(s) but no the large one(s).
The measure tool works fine.
Solved by lichtzeichenanlage. Go to Solution.
Dimension tool only works on 2d sketch articles, your articles moved off the sketch plane are now 3d articles - done to you automatically by Fusion.
Might help...
Is it possible that you've drawn everything in one sketch? IMHO you cannot dimension sketch elements in the 3d space. Because of this it's easier to use two sketches like shown in the video.
@davebYYPCU: Should have refreshed my browser. Those screencast uploads are just to slow...
I see...that makes somewhat sense. Though trying to figure out why everything else worked except dimension was frustrating as anything. I even did create a sketch at the new placement, but that did not "import" the sketch objects to allow dimensioning...
Thank you for the screencast, ill convert to that method.
Sorry bout that, and that i didnt see this post when you made it...fixed now.
