Cannot delete translucent blue object in design
I am currently designing a lightsaber hilt in Fusion. I noticed this mesh (attached below) in my design. I've turned off all objects, sketches, planes and anything else it could be. I have deactivated the master component, and it still wont disappear. The mesh cannot be selected at all either. After scouring the design history I had no luck in finding where this came from. My best guess is that they are artifacts from when the object was extruded? Regardless please help to figure out how to remove these meshes from my design.
dsouzasujay
Hi @Anonymous ,
Please attach prior designs that you have already completed in Fusion 360.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Here is the f3d file
dsouzasujay
Hi @Anonymous ,
The bodies are you have highlighted in the first post are hidden and will show preview when you click on top browser node on the hidden body.
If you dont want to see them, try to find the hidden body, Right click and remove.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
