Cannot convert a body to a component
lesUZTMG
lesUZTMG
Rt-clicking a body does not show "create components from bodies". The list of items shown is:
Create selection set
Configure
Properties
Save as mesh
Copy
Show/Hide
Isolate
Find in Windows
Why is the menu list different from the one that includes "create components from bodies"?
The design was opened from the data panel.
jhackney1972
This Forum post is a repeat of this Forum entry.  Please do not duplicate post.
John Hackney, Retired
lesUZTMG
Here is a screen shot of my Browser and results of rt-clicking on a body.  In the past the menu would be longer and have the "create components from bodies" option.  What's causing this new menu to appear?
jhackney1972
I do not have a direct solution.  The first thing I would do is close and restart Fusion 360 to see it that corrects the issue.  If that does not, I would use the Fusion 360 Service Utility and select the Repair option.  Here is the link to how to use the utility.
TrippyLighting
I believe you are working with a linked component also called a XREF for external reference.
This can only be modified in the original fil you inserted.
However, you can use the surface/boundary fill tool to copy that geometry anywhere in your target design you want to.
lesUZTMG
I re-installed Fusion and the problem went away.
lesUZTMG
I couldn't run the repair facility because I was getting missing dll messages.  I eventually uninstalled, then reinstalled fusion, and the problem went away.  Thank you for your suggestions.
