I want to assemble the box but mirrored sides are somehow linked and tied together. And I cant assemble the sides with joint as seen in the video. How can I break the link?
Solved by Beyondforce. Go to Solution.
Hi @Anonymous,
If you followed R.U.L.E #1 you would understand why! You need to change the mirrored body to a Component. You cannot use joints on bodies only on Components.
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Owner, TESREG.com & Fusion 360 NewbiesPlus
TESREG - Fusion 360 Hardware Benchmark
Facebook | YouTube
Hi @Anonymous,
Cheers / Ben
Ben Korez
Facebook | YouTube
Those box sides were one component. I changed them to separate components and then I was able to assemble them 🙂
