Can you have more than 1 instance of Fusion 360 running on different computers?
Does Autodesk "allow" you to have more than one instance of Fusion 360 running on more than one computer?
I'll frequently change workstations and sometimes I'll be logged into my Fusion 360 account from more than one machine. I anticipate being logged in from a design workstation and then going to a CNC production workstation and outputting from there.
I've been trying to track down some save session problems and wonder if this might be a contributing factor. Today I got an outright "Autodesk Fusion 360 has stopped working" error message with a close program button.  I chose the option of sending you the logs so hopefully you can see it on your end.
Phil.E
Yes you can log in to more than one workstation at a time.
In your case, you should be sure that a saved file is completely done saving before trying to work with it on another system. The save > upload process can be longer than anticipated if you have a large file and slow upload speeds.
I see your crash report and have forwarded it to the relevant team. Thanks for adding the detailed comments.
Phil Eichmiller
Software Engineer
Quality Assurance
