Can you fix interferences?
Trying to run a stress simulation but I can't because my model has interferences.  How can you fix interferences without going into your model and manually doing each and every one?  I have seen screenshots where you can 'keep' then,  but I am not getting that option.  The dialog box shows the 'keep' option but I cannot select it.  It would be really disturbing if I have to go and manually fix all of these little interferences that are absolutely tiny.
John_Holtz
Autodesk Support
Autodesk Support
This post is a duplicate of this one: http://forums.autodesk.com/t5/design-validate-document/can-you-fix-interferences/td-p/6822983
I am closing this post by marking it as solved. Please see the other post for the continuation of the issue.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
