Can you draw a Center Rectangle without the construction lines?
traditional.builds
traditional.builds
Just a simple and dumb question but have not found an answer for this. It's not really bothering me but depending on what I am drawing 8/10 times I end up deleting the construction lines inside the center rectangles. I have not found a way to create the rectangle without these lines.
I sort of get why they are there, but at the same time I have no real use for them and tend to clutter my drawing when I just need the rectangle/square shape. What is the intent of these construction lines? Are they just guides? Why are they not on 2-point rectangles if they are important for the center rectangle?
Mostly just curious, after deleting them countless times I figured I'd ask. What do you guys use them for?
TheCADWhisperer
I don’t know why you would delete them, but you can create  2pt corner Rectangle without them and then simply add constraints to the midpoints to center the rectangle.
jeff_strater
what are the construction lines for?  They are there to locate that center point, and keep it in place when the rectangle changes.  Without them, it is just a 2-point rectangle.  I guess I don't understand your workflow here.  Do you just want an unassociated center-point rectangle?  Meaning:  that point is only used during creation of the rectangle, but, from then on, it is just a 2-point rectangle?  If so, no, there is no way to do that.
Jeff Strater
Engineering Director
HughesTooling
If the rectangle is aligned horizontal\vertical you can add a point and constrain with Horizontal\Vertical constraints between the point and midpoints of the rectangle.
This will not work if the rectangle is rotated, hence the need for construction lines.
Mark
Mark Hughes
Owner, Hughes Tooling
g-andresen
How should a 2 point rectangle know where its center is?
günther
