Can this be done, bring in things to use in cad
I would like this letter (it is not a font) in a format that I can drop it into a cad for extrusion. I would also like to be able to control the scale/size.  Can this be done. Is this something I will need to pay to have done?
drew
Best long term way is to bring in the image and scale it to something sizable, build a parametric sketch of it so that you can resize it as needed.  Might start with a "bounding box" with Width and Height dimension control to allow for easy resizing / scaling.  Also, might want to try starting with live trace if it in AI if you have access and then export as DWG to get a easier start to the sketch.
TrippyLighting
Simply import the image and trace it with splines. Us as few spline points as you can get away with.
PhilProcarioJr
@Anonymous
Convert this with Inkscape and save as a SVG, bring the SVG into Fusion. This can be done in less then a min.
Phil Procario Jr.
Owner, Laser & CNC Creations
