Can't select text
Can't select text
jdaues
Can't select text
jdaues
I've created 2 sketches. One is a box. The other is text on the top surface of that box. I want to extrude the text up from the box but I am unable to select the text. When I select and extrude, it selects the entire rectangle of the text sketch and extrudes that to another box. I've watched 3 videos of people extruded text and my environment is not behaving like theirs. How do I select this text?
johnsonshiue
Hi! I am not sure if Tspline Extrude supports text profile. You may extrude the text using the regular Extrude command. Then convert the body to Tspline.
Many thanks!
Software Test Engineer
jdaues
Thanks for your reply. I didn't know that there were 2 kinds of extrude. If I pull down Create > Extrude, I see that it is indeed a Tspline extrude. So I would like to try using the extrude command. However, when I type in Extrude in the command line, I get "There is no command Extrude. Use ? to get help on available commands"
How do I access this other Extrude?
TheCADWhisperer
There are actually 3 types of Extrude.
(view in My Videos)
pkomatlapalli
Hi @jdaues,
I hope you’re doing well. Can you please let us know if the suggestions from johnsonshiue and TheCADWhisperer helped resolve your question?
If they did, kindly consider marking it as an Accepted Solution so it can help others in the community. If not, please feel free to share an update, and the community will be happy to assist further.
Pavan Kumar | Community Manager
