Can't select object to form circular array
I am new to fusion and trying to migrate from Sketchup. I am working through some tutorials and having some difficulty. In this example I am trying to create a circular array of the arc between the pins. I believe I am following step by step but when activating the array function I am unable to select the arc ( I can select the center point but not the arc), I click on it and nothing happens, I have started over several times but always with the same problem. I have not been able to find what I must be doing wrong.
Here is the tutorial:
https://myhub.autodesk360.com/ue29c9141/g/shares/SH7f1edQT22b515c761e0fb7299f18edd451
This is where I am having an issue:
g-andresen
Please share* the file.
S we can analyse the current status.
* File > export > save as f3d locally  > attach it to the next post.
günther
Here is the file
Rob
wmhazzard
The tutorial is using a much older version of Fusion and it is different now. The sketch pattern has to stay in the sketch so go back and edit sketch 4 and select circular pattern there.
Thanks, that worked. This is one of many issues I have had trying to follow along with tutorials/videos. I will get to a point or operation  when the software I am using does not function as described, sometimes I can work it out,  I have suspected the problem is different versions, but in some cases I am simply dead ended, like this one.
Thanks again for taking the time to help and if you know of an up to date tutorial I would be grateful. As a woodworker my needs are fairly simple.
Rob
TheCADWhisperer
@Anonymous wrote:
 I have suspected the problem is different versions,...
There is more than issue with different versions - Steps 8 and 9 are poorly written.
